Swapping the 398 for a fresh from the machine shop 306. Forged pistons are TRW cut for a 2.08/1.6 valve, crank and rods are ford parts.
Ive got a few parts I want to carry over from my W build, for cost and time saving purposes.
Timing cover and waterpump will make the jump. Timing cover has a plate for a mechanical pump drive but has been blocked. Waterpump is the wrong rotation if I remember right but its run off a Moroso drive so its a simple polarity swap.
ignition system minus the dizzy, carb and headers will carry over as well. With a swap to an 8.2 Vic Jr intake.
The only stumbling point is the AFR 205's. Ive seen a 306 with a set of 185s cut to 205 specs haul to a few 10.0x passes but it was on a healthy shot and had a custom cam. was far from a dog off the bottle but the nitrous really helped move things along.
I'm not beyond spraying, as ive done it before. And ive considered going forced induction in the semi-near future anyways. Don't want to go to a set of 185s if they will be my bottle neck eventually but on the otherhand without more cubes that may not be a concern.
In terms of a camshaft, ill have a NIB TFS2 but I don't think that's the ticket so ill be trying to spec one of those as well.
I understand there are more important specs than the intake port size, just wanting to hear from who's done it and how successful they were or weren't.
