Big Help in a hurry!!!!
Hey, my friend bought a 90 lx s'charged. It has stock manifold, heads, cams, throttle body. Recently it has been chuggin, takin a few triesd to turn it over and to keep it running. Now today it doesnt stay on at all. It starts, then gets real choppy, rpms are all over the place, then it will quit. Ive tried to give it gas from start up and all it does when the rps drop is just quit. I think it has the oil it needs, and the coolant, so on so forth. If it helps its a novi 1k. its a funky aode. what could it be? i have a half tank of gas, 93 octane, ive checked airways and all seems decent. could it be a dirty maf? or throttle body? what else could it be, thx for the bigtime help in advance.
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
