Big Problem...........help me solve it
mytight95
2,605
Dothan,Al
Ok i seem to have lost one of the bolts that bolt the rocker arm to the head.. :( .............they are the ones for the 1.7 ration Crane Cams......rocker arms........same ones used in the cobras...........
can i go to a hardware store and match it up to one that same thread count length etc. or do i have to try and custom order one...........i would think i could go and just match one up.........but i am sure it has to be a strong bolt to take all that pressure of the rocker arms
thanks............
jason
This is one of those situations where I wouldn't try to cut any corners. That bolt is for a critical system with a moving part that takes a lot of stress. I would probably just call crane cams and order a replacement (and maybe a couple spares). I have found that companies are usually pretty good about this. I lost a couple bolts and retainers for my stage 8 header bolts and they replaced them for free.
i found some grade 8 bolts that are exactly like the ones i had in every dimension even have the same markings on them in the same places...........they are grade 8........they should be plenty strong enough.............RIGHT??????
jason
I had a rocker bolt break on me too. I went to home depot or whatever and got like 20 grade 8 bolts for around $12. I replaced all my rocker arm bolts. They are more than strong enough. I even went back and got some for my valve coves since the fox covers use a longer bolt and I wanted the nice gold look the ones they sell had.
jason
As long as the thread pattern, and bolt length is the same, then you should be just fine. I can't imagine what difference a different bolt would make. They aren't like our stock head bolts from what I know. Since it's grade 8, I wouldn't think twice about using it.
Scott
