  • 2.3L (N/A & Turbo) Tech
big tranny problem
  • Thread starter Thread starter youknowit62300
  • Start date Start date Jul 31, 2004
Y
youknowit62300
24
Wichita Kansas
Jul 31, 2004
  • Jul 31, 2004
I have a big problem i think when i start my car (stock 87 4cyl.) tranny fluid runs out of the bell housing? any ideas what that could be???? i was thinking maybe front pump seal. how hard are those to change thanks,
ps it is auto
My80Cobra
228
Spokane, WA
Jul 31, 2004
  • Jul 31, 2004
Sounds like a front seal. Do yourself a favor because you have to pull the transmission anyway and slap the t-5 5 speed in it.
Y
youknowit62300
24
Wichita Kansas
Jul 31, 2004
  • Jul 31, 2004
i wish i could but i don't have the money right now to buy the other tranny otherwise i would do it that way i can buy the seal from autozone for 5 bucks any idea how hard it is the put it in? guess i am going to be learning how to put one in lol
P
Pro-Hawk
971
West Texas
Jul 31, 2004
  • Jul 31, 2004
The seal is cheap but changing it is a PITA. I think AutoZone sells them but if not a local transmession shop will. I blieve you will have to pull the whole gear box to swap this seal. Once the gear box is unbolted becareful the torque converted just don't slide off and break a toe etc Just slide the torque converter off and place it to the side. The seal should be able to be prided off with a screw driver but double check this. The new seal should be taped in place with a soft rubber hammer or butt of a screw driver. Then you slide the converter on making sure not to hurt the new seal. If it was me I would check and see what a transmession shop would charge...I can't stand transmession fluid anymore, exspecailt burnt transmession fluid
My80Cobra
228
Spokane, WA
Jul 31, 2004
  • Jul 31, 2004
I think it is easier to pull the whole thing bellhousing and all. When you put it back together make sure you put the torque converter on and turn to the right at the same time, it will click and slide further on to the shaft 3 times. Make sure you do this or you will have a hell of a time (don't ask how I know). I had the motor out and learned the hard way that the hard way trying to put it back in.
Y
youknowit62300
24
Wichita Kansas
Jul 31, 2004
  • Jul 31, 2004
cool thanks for all the info i am going to get started on it tomorrow hopefully have it done who knows
mr_woodster
1,314
Riverside, CA
Aug 1, 2004
  • Aug 1, 2004
well, save your pennies! It will be comming out again soon.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 14, 2026
joeybuddy96
J
C
99 mustang gt no signal to fire coils
  • Cerana04
  • Oct 4, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2025
Cerana04
C
