Bigger Injectors?
  • Thread starter Thread starter 87_5.0
  • Start date Start date Aug 12, 2004
87_5.0
73
  • Aug 12, 2004
If I go to a 70mm throttle body, and a 76mm C&L mass air, do i have to get bigger injectors? I have stock 19's now. thanks,
Brent
stangbear427
2,401
New England
Aug 12, 2004
  • Aug 12, 2004
No. Just make sure you get the MAF with the sample tube for 19#
88stangmangt
2,332
Stafford,VA
Aug 12, 2004
  • Aug 12, 2004
no if you ever want more before you smack down some $$$ for bigger injectors get a adjustable FPR.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Aug 12, 2004
  • Aug 12, 2004
The stock injector is capable of flowing 19 pounds per hour of fuel. Whether you need more injector or not is a function of how much power you're making. Go to www.pro-flow.com and select the 'meter sizing' tab. Scroll down and you'll get an idea of what size injector it takes to meet certain HP requirements. The 19's will comfortably support something like 75-100 more HP than the stock motor makes, depending on how the car is used, at stock fuel pressure levels. Your changes don't have you anywhere near that HP level, so you're not in any danger of outrunning the stock injectors. With the C&L maf, you can easily change the maf for larger injectors in the future if you make other mods that require larger injectors to keep up with the airflow/HP level.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
