BLACK INTERIOR CONVERSION PAINT JOB QUESTIONS?? HELP
  • Thread starter Thread starter biglg
  • Start date Start date Apr 14, 2006
biglg
64
  • Apr 14, 2006
I have an 89 gt convt. I want to do a black paint conversion. First, is Duplicolor paint ok? I read a few people who have used it said it worked great. I can get it locally and it is cheaper than SEM and some others.
Secondly, they didnt make black interior for 87-89 convt. stangs. So the seatbelts are currently gray. What can i do to get them black? If I paint/dye them, wont it rub off on clothes and be a mess?
Did anyone paint the dash gauge bezel?
Do I have to buy black carpet for the front lower part of the doors, and the lower part of the rear interior quarters on my vert, or is there something that will paint them and look ok?
All tips, steps, brand of paints, brand of clear coat, etc would be appreciated. I will have the rest of my interior out today. I am ready to get this done.
What kind of paint and clear coat did everyone use? Do I need a clear coat?
Thanks guys!
BDASPNY
103
HAMPTON ROADS
Apr 14, 2006
  • Apr 14, 2006
ttt
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Apr 14, 2006
  • Apr 14, 2006
I used duplicolor, prepped it well, and no clear. I used the flat black color not the gloss black, scuffed the parts well. Cleaned them well and used and adhesion promoter. I havent installed it yet, so have NO idea how it is going to hold up, but will know in a few months. No clear coat either.
GreatWhite
232
Fairfield, PA
Apr 14, 2006
  • Apr 14, 2006
Did the same. ^^
Came out pretty well.
K
kreacher5.0
122
  • Apr 14, 2006
Wow im glad I have 2 sets of origanal black interior.
BullittAndy
139
  • Apr 14, 2006
I don't think seat belts can be painted/dyed. The plastic pieces need to be cleaned with soap and water, then with alcohol/similar agent and then sprayed with light coats. IF the plastic/vinyl is clean then it will stick like crazy, but scuff marks have to be touched up. I sparyed my grey interior with the vinyl spray cans (grey) from Autozone and it has held up perfectly for 6 months.
Remember, clean, clean and clean.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 14, 2006
  • Apr 14, 2006
Dye works amaizing if the prep work is done well...wash it with soap and water several times..scuff it and wash with dish soap and water again...maybe even a plastic prep spray if available. The more prep work you do the better the adhesion will be. My personal preference would be to dye all but the most common areas of contact..I.E.arm rest/center counsel..the areas of high contact might be best off if they were initially black pcs..these will obviously hold up better to constant contact with your body and it's oils/cleaning solvants.
Fett
766
  • Apr 14, 2006
I used SEM vinyl dye, specifically "landau black". It is in between glossy and flat. It doesn't gloss like paint, but you can use black magic, or any other interior stuff on it and it looks awesome.
I used it on my door pulls, center console, dash, instrument cluster bezel, AC control bezel, dash pad, and AC registers....pretty much everything. I had a combination of colors, some red peices, some blue, some grey, and some black. I used brake parts cleaner to prep all my peices. The brake parts cleaner will strip any waxes, cleaners, and stock paint right off. Let them dry, then use a few coats of SEM. You can't tell they have been painted.
Let the dye dry, clean them up with some black magic, and install them. I would use a little white out on the icons on the AC registers though, with them all black it is OBVIOUS that they have been dyed. The little things like that make the whole thing look stock.
As far as seatbelts, your best bet is to go boneyarding. Check every car, you would be suprised how easily black seatbelts can be found. I found them in a varity of colored interor Mustangs. Be careful of the year though, the 87-89 Mustangs and the 90-93 have different mounting locations for the rectractor, so they will not lock you in during an accident. You need to make sure you mount them correctly by cutting a guide slot in the sheet metal, or the seatbelts won't lock in. during foreward momentum.
GreatWhite
232
Fairfield, PA
Apr 14, 2006
  • Apr 14, 2006
I got black belts out of a 92 and they bolted right up in my 89....?
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Paint and Body What to use to clean up/prep painted surfaces before painting
  • AnthonyA1234
  • Sep 27, 2024
Fox 5.0 Mustang Tech Sep 28, 2024
limp
