BLACK INTERIOR CONVERSION PAINT JOB QUESTIONS?? HELP
biglg
64
I have an 89 gt convt. I want to do a black paint conversion. First, is Duplicolor paint ok? I read a few people who have used it said it worked great. I can get it locally and it is cheaper than SEM and some others.
Secondly, they didnt make black interior for 87-89 convt. stangs. So the seatbelts are currently gray. What can i do to get them black? If I paint/dye them, wont it rub off on clothes and be a mess?
Did anyone paint the dash gauge bezel?
Do I have to buy black carpet for the front lower part of the doors, and the lower part of the rear interior quarters on my vert, or is there something that will paint them and look ok?
All tips, steps, brand of paints, brand of clear coat, etc would be appreciated. I will have the rest of my interior out today. I am ready to get this done.
What kind of paint and clear coat did everyone use? Do I need a clear coat?
Thanks guys!
I used duplicolor, prepped it well, and no clear. I used the flat black color not the gloss black, scuffed the parts well. Cleaned them well and used and adhesion promoter. I havent installed it yet, so have NO idea how it is going to hold up, but will know in a few months. No clear coat either.
I don't think seat belts can be painted/dyed. The plastic pieces need to be cleaned with soap and water, then with alcohol/similar agent and then sprayed with light coats. IF the plastic/vinyl is clean then it will stick like crazy, but scuff marks have to be touched up. I sparyed my grey interior with the vinyl spray cans (grey) from Autozone and it has held up perfectly for 6 months.
Remember, clean, clean and clean.
Dye works amaizing if the prep work is done well...wash it with soap and water several times..scuff it and wash with dish soap and water again...maybe even a plastic prep spray if available. The more prep work you do the better the adhesion will be. My personal preference would be to dye all but the most common areas of contact..I.E.arm rest/center counsel..the areas of high contact might be best off if they were initially black pcs..these will obviously hold up better to constant contact with your body and it's oils/cleaning solvants.
I used SEM vinyl dye, specifically "landau black". It is in between glossy and flat. It doesn't gloss like paint, but you can use black magic, or any other interior stuff on it and it looks awesome.
I used it on my door pulls, center console, dash, instrument cluster bezel, AC control bezel, dash pad, and AC registers....pretty much everything. I had a combination of colors, some red peices, some blue, some grey, and some black. I used brake parts cleaner to prep all my peices. The brake parts cleaner will strip any waxes, cleaners, and stock paint right off. Let them dry, then use a few coats of SEM. You can't tell they have been painted.
Let the dye dry, clean them up with some black magic, and install them. I would use a little white out on the icons on the AC registers though, with them all black it is OBVIOUS that they have been dyed. The little things like that make the whole thing look stock.
As far as seatbelts, your best bet is to go boneyarding. Check every car, you would be suprised how easily black seatbelts can be found. I found them in a varity of colored interor Mustangs. Be careful of the year though, the 87-89 Mustangs and the 90-93 have different mounting locations for the rectractor, so they will not lock you in during an accident. You need to make sure you mount them correctly by cutting a guide slot in the sheet metal, or the seatbelts won't lock in. during foreward momentum.
