Blaster TFI Coil ?
95WhiteVenom
624
Alabama
Well I need a new coil. I thought that I might as well try the BLASTER TFI out. :banana: Has anyone used one of these before? Is it good? How easy is installation? Is there anything i'lll need to get other than the coil? Sorry to make this complicated just want to make sure I got all the info.
BTW I do not have MSD ignition if that is an issue as well. :(
I have the MSD Blaster 45kv coil. Installation takes literally the time it takes to take out 4 bolts, swap the two, and bolt them back in. I think the bolt size is wierd though, its like 7/32s. Directly replaces the old coil regardless of what ignition you are using. Just be careful when you remove the old coil; when you unplug the electronics, try not to snap off the clamps on the sides of the connector. They are very delcate. I snapped off one of mine and it pisses me off to this day. Lastly, the coils get hot as a mother even after a 5 minute drive so let the car cool first or wear gloves.
that should be everything you need to know about swapping coils that I can think of.
i have the MSD TFI coil too.. and everything you need to know has already been said.. easy installation and all that.. and BLack95GTS warned you already but ill back him up.. it gets really freaking hott really quick.. so be careful
