  • SN95 4.6L Mustang Tech
Bleeding ABS system...
  • Thread starter Thread starter Marlboro_Man
  • Start date Start date Feb 8, 2009
M
Marlboro_Man
437
Houston, TX
Feb 8, 2009
  • Feb 8, 2009
Ok, When i bought my 2002 GT it had some probs. One of the first i noticed was the drivers side rear banjo bolt was almost all the way out. Fluid was leaking everywhere. I trailered her home, and tightened it up.
I bled the brakes and MC with a one man bleeder kit till there was all new fluid in the ssytem and no bubbles coming out anywhere. I changed the pads all the way around, the rotors appear to be in good shape.
Still the brakes suck horribly. I believe it's caused by air in the ABS module. I know you have to have an expensive scan tool to bleed it.
IS there any other way of doing it with out the scan tool? Like maybe jumping two wires together to trick the abs module into opening?
:SNSign:
nyuk98gt
1,427
Chesterfield, MO
Feb 8, 2009
  • Feb 8, 2009
Marlboro_Man:
Did you bleed the master cylinder, too? There are two bleeders on the engine side of the m/c that should be bled anytime the four corners are bled. The rear bleeder is for the front brakes, the front bleeder is for the rears.
Take a look at "StangPlus2Birds" website: h t t p://w w w .veryuseful.com/mustang/ (take the spaces out to make the link work) -- he has some great info there!
HTH,
Chris
M
Marlboro_Man
437
Houston, TX
Feb 8, 2009
  • Feb 8, 2009
Yes i bled the master cylender.
Thanks for the link, I'll check it out.
M
Marlboro_Man
437
Houston, TX
Feb 8, 2009
  • Feb 8, 2009
according to the website you have to use a scan tool. Which , I already knew. I was just hoping there was a "hack" or something, like a way to jumper two wires to activate the system. I was hoping to do this at home, but...
On the other hand i may have access to an NGS tool through a friends work (the power company) , They have all ford trucks and have their own mechanics to work on them, and the have an NGS.
Ford wants $85 to diagnose it and another $280 to bleed it with the NGS tool if they find it needs it...
G
66’ drum bleeding
  • Geno66
  • Sep 1, 2025
Classic Mustang Specific Tech Sep 8, 2025
GOvert
G
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
O
ABS light on. Can't get codes
  • oldtimeracer
  • Jul 12, 2024
4K
SN95 4.6L Mustang Tech Aug 28, 2024
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
