Bleeding The Brakes.
Those instructions are great. If you had Russell Speed Bleeders, you could do it by yourself a lot faster. They are basically a one way check valve. They let fluid out, but no air in. They make brake bleeding really easy, and are relativly inexpensive. Just a thought...............
:stupid:
you could also get a vacuum pump which is also a great way to bleed brakes, for what its worth its the only way i use.
