  • SN95 4.6L Mustang Tech
Blew a Head - Questions ..
  • Thread starter Thread starter Spidey
  • Start date Start date Jan 15, 2008
Spidey
37
Las Vegas, NV
Jan 15, 2008
  • Jan 15, 2008
So the mechanic was replacing my intake manifold (lovely cracked plastic) on my 99 GT with the new metal/plastic one, he informed me that I also cracked one of my heads.
I did a search and got some good info, but I'm looking for some more specific, any help is appreciated.
1. I know the car takes Windsor heads, but should I get Romeo (will they work?) heads instead?
2. Any recommend places to buy them? Used or new? Cheapest places I've seen are $425/ea (new)
3. Any place just to buy the head itself without the cams? I haven't found any and from what I understand, it's just the outer wall that has a crack. Doesn't sound like it'll be repairable, but the cams should work.
Since the guy is going to be working on this general area of the car, I figured I'd might as well replace the stock headers. Any thoughts on good brands? MAC?
RandyStinchcomb
1,159
Randallstown, Md
Jan 15, 2008
  • Jan 15, 2008
ummm, how did the head crack? sounds fishy to me, Id ask to sea where it's cracked...if you do need a head(s) stay wth the Windsor's, so you dont have to change-out the front cover bolts/studs and the cam covers....
Spidey
37
Las Vegas, NV
Jan 15, 2008
  • Jan 15, 2008
Unfortunately, it doesn't appear to be a scam. The guy was doing us a favor (doing the intake swap for $100, I buy parts). He's not charging me extra for this. I just have to get the parts for him.
RandyStinchcomb
1,159
Randallstown, Md
Jan 15, 2008
  • Jan 15, 2008
ok, whatever, I've never heard of a modular head cracking
Matt's 03 GT
Orange County
Jan 15, 2008
  • Jan 15, 2008
Spidey... if you don't know Randy is the best ford parts guy. He knows these cars in and out... If he hasn't seen one crack before just be carefull. Perhaps you can get a second opinion???
Spidey
37
Las Vegas, NV
Jan 15, 2008
  • Jan 15, 2008
I don't doubt that he know's his stuff. I do know the car overheated on numerous occasions, which would lead me to believe.
I'm going through second-hand information, so the mechanic is supposed to double-check it. From what I've been told, he didn't notice the crack until he got it all buttoned back up and did a water test on it. He noticed the water mixing with oil apparently. Does that sound remotely plausible?
Matt's 03 GT
Orange County
Jan 15, 2008
  • Jan 15, 2008
Water in the oil would point to head gaskets as far as I know... I am always hesitant about mechanics who do favors like this... It always makes me nervous and when they come up with stuff like this I tend to run away and have my car towed somewhere else.
If the head realy is cracked you should be able to get a head from the junkyard. Through search I am sure you could find all of the vehicles that had this specific motor. You may just need to swap cams if the head is out of a different model... just a thought.
ADRENLN
2,342
NJ
Jan 15, 2008
  • Jan 15, 2008
i sold both my pi heads on ebay for about $350. you should be able to find used that are perfectly fine and cheap. they are all over the place from guys stepping up to ported heads...just look around. check the classifieds hear as well.
eliteJAE
Stanford University
Jan 15, 2008
  • Jan 15, 2008
go take a look at the heads for yourself, see if you can spot the crack as well. windsors are just as good as romeo's as far as i know, so if you have windsor engine then use windsor heads. if you dont mind used heads check out a junkyard or the national classifieds here on SN, i remember i was looking for a pair a while back and found some real cheap.
i dont know if these doods are legit, but they have a 1-800 number to call to.
http://usedautoparts.everdrive.com/partdetails.aspx?sku=105327
Superhereaux
chicks make me feel inadequate
538
South Texas
Jan 15, 2008
#10
  • Jan 15, 2008
  • #10
sounds more like a blown head gasket, that would be very plausible if the car's been overheated
head down there and take a look for yourself
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Jan 16, 2008
#11
  • Jan 16, 2008
  • #11
jb weld time
SilverBullet00
1,150
Wichita, KS
Jan 16, 2008
#12
  • Jan 16, 2008
  • #12
Sounds like the head gasket to me as well. I'd take the heads off the car and take them to a cylinder head repair shop and have them pressure tested and checked out. You might have a warped head as well...
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Saturday at 1:54 PM
limp
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
