Blinkers
  • Thread starter Thread starter Kevin87
  • Start date Start date Feb 27, 2013
Kevin87
Grundy Va
Feb 27, 2013
  • Feb 27, 2013
I have an 87 gt. I have hazzard lights but no turn signals, Ive changed the flasher under the steering wheel. I have took the hazzard switch off to look for losse wires. How can I test my turn signal switch? any other things I can look for? thanks
HISSIN50
34
129
Feb 27, 2013
  • Feb 27, 2013
To confirm, you changed the TS flasher - it's generally on a loose pigtail?
Are all of the fuses intact?
Is there power going into the TS flasher when the TS is activated?
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Feb 27, 2013
  • Feb 27, 2013
My TS Flasher was behind the glovebox on my Stang.
blackfive-o
29
Feb 28, 2013
  • Feb 28, 2013
Check the ignition switch on the steering column. It is probably coming apart.
Kevin87
Grundy Va
Feb 28, 2013
  • Feb 28, 2013
Yes the flasher was on a loose pigtail under the steering wheel, all fuses look to be intact. As for the voltage going to the flasher I dont know the batts. in my meter were dead that day I was working on it. Can I jumper one of the plugs that go's to the TS lever to see if it makes up? thanks
HISSIN50
34
129
Mar 1, 2013
  • Mar 1, 2013
Use or make a test-light and check for continuous power (when the TS is turned on) into the flasher and pulsed power leaving it (the test light should pulse like a turn signal).
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
