I have an 87 gt. I have hazzard lights but no turn signals, Ive changed the flasher under the steering wheel. I have took the hazzard switch off to look for losse wires. How can I test my turn signal switch? any other things I can look for? thanks
Yes the flasher was on a loose pigtail under the steering wheel, all fuses look to be intact. As for the voltage going to the flasher I dont know the batts. in my meter were dead that day I was working on it. Can I jumper one of the plugs that go's to the TS lever to see if it makes up? thanks
Use or make a test-light and check for continuous power (when the TS is turned on) into the flasher and pulsed power leaving it (the test light should pulse like a turn signal).
