Block dowels
  • Thread starter Thread starter Mr. Rustypwnz
  • Start date Start date Dec 11, 2006
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Dec 11, 2006
  • Dec 11, 2006
Yo, Im ordering alot of stuff tonight for the beast, im down two head to block dowels, do you absolutely have to have em? I know they help keep the hg in place but im gluing the thing in place for when I put the heads on, so they wont slide off.
josh
Blk91stang
607
North Brunswick, NJ
Dec 11, 2006
  • Dec 11, 2006
Gluing the headgaskets in place? What do you plan on using to "glue" them onto the block and what kind of headgaskets are you using?
Why not just do it the right way and get some $2 block dowels to locate the head and the gasket upon installation.
There is a good change your "gluing" technique will cause a blown headgasket after 1 min of runtime. For the head gaskets to seal, the surface mating areas need to be FREE of ALL DEBRIS, including glue!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 11, 2006
  • Dec 11, 2006
The quick subsittute for the dowels is some 1/2" diameter hard copper pipe about 1/2" long. You cut a slit in the pipe from one end to the other. The width of the slit enables you to trim the pipe to exactly the right diameter to fit in the holes in the engine block. Any home store or hardware store will have the 1/2" copper pipe, and you need about 6". That gives you some leftover pipe to play with if you don't get it right the first time.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Dec 11, 2006
  • Dec 11, 2006
Im not going to actually glue the whole things on there, just put a spot or two in the corners, Ive done it before, but I had the dowels, oh well I guess i bought some dowels!!1
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 11, 2006
  • Dec 11, 2006
The dowels are there to align the heads with the block, not just just the gaskets. It really does make things easier.
rd
3,316
63
109
Ocean Springs MS
Dec 11, 2006
  • Dec 11, 2006
Yes, you absolutely need the dowels. In a pinch, try a machine shop to see if they have some leftovers. Several places sell them, including Ford, alone, or as part of kits. They locate the heads to the block properly.
ozanracing
172
  • Dec 11, 2006
Trickflow sells them for a few dollars.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
T
Convertible A-pillar weatherstrip issues
  • thiefofcheese
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 20, 2025
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
