Block is cracked, questions
88SC_GT said:
i saw it only lifts 512 too which would allow me to keep the stock afr springs.
It's been awhile since I've been on the AFR website. When I had my 165's they suggested a spring upgrade when using hyraulic roller cams. This is due to the aggressive ramp rates or something like that. I bought mine from Ed C. @FTI. Check him out for you're cam if you can swing the money for a custom ground. Are you keeping this motor n/a? If so what are you considering for compression?
mike.
Ed's Spring and Viton Seal upgrade will run you right under $200, worth every penny. The custom cam $325, and to be honest every Ed cam I have installed has worked very well.....worth the wait and money.
Do it once, do it right.....
well i dont have that much money to be getting a custom cam and new springs right now. im thinking later on when i want to add a 5-8 psi blower, ill have a real custom cam made then.
meanwhile ill just get a 270hr or 274hr and it will be plenty for the rare times i even get on it.
30's? isint that a little big for my setup?
30s with a 331 and 185s....should make some nice POWA!
ok, im going to be paying for most of my stuff today. this is a quick rundown, see anything questionable now then?
331 scat stroker shortblock.
afr 185's
274hr cam
30 pound injectors
80mm maf
70mm tb
1 5/8" equal length headers
2 1/2" h-pipe
1.6 rockers
hardened stock length pushrods
thanks
forgot to mention a couple things.
intake will be a ported/polished performer rpm
will pick up a canton oil pan
what range of power does a 331 typically make with these mods? 300 rwhp should be fairly simple right, thats what im expecting/going for out of this.
