Progress Thread Block transplant (and more)
I just dropped off the new block along with new cam bearings and my existing rotating assembly at Bob Weaver Racing in York PA. Bob checked everything out and blessed my plan of transferring my assembly to the new block. He’s going to finish hone, true the decks and put the cam bearings in. Not only did he not BS me, he taught me a few things I didn’t know.
Well worth the trip from Annapolis MD! I’m stoked!
If you do not mind and if Mr Weaver does not mind can you give us a ball park idea as to the cost when he is done? I am looking at the same thing and would like to do it over the winter but do not want to pull the working motor if I do not have the coin to do the work.
I’ll run it by him when I pick the block up. He’s a really nice man and I don’t think he’ll mind but it’s always nice to ask first. I took an annual leave day Dec 3 for the drive to pick up. He said he’ll probably be done before that as he’s wanted to clear the slate because it won’t be long before the racers will be dropping off their winter projects.
It’s funny you know. We were tuning and I was privately griping about having to track down the bank imbalance by trying things like swapping the o2’s and stuff…
Now look :rolleyes:
By the way I think the leak I was trying to fix was the cracked block all along. It was doomed either way. Look at the cracked area on the inside of the water jacket. If has sludge on it. I’m thinking it wouldnt be like that unless it had been run for a little while at least. I never ran it after discovering the crack so it had to already be there
Reactions: DadLife0724
The machine shop called and my Boss 302 block is ready. I’m picking it up Dec 3.
The cylinders needed enough material removal that it couldnt properly be done by honing alone. I think he said .009” had to be removed with boring first. He then finished hone to .0030 piston to wall clearance which is the loose end of the Ford spec range (.0015-.0030) for these pistons from the assembly line.
The decks needed attention. No problem because Ford puts an extra .010-.015 on top of the 8.2” on these blocks. To make both sides equal from the crank center line and level them front to back he took off .005” of one side and .007” off the other.
Cam bearings and rear cam bore expansion plug installed.
All the other expansion plug and oil galley plugs are screw in with orings. I got a full bag of them all that came with the block. It will be really easy to drain the block from here on out.
It interesting because Bob Weaver called me more than once during the process of conditioning the block to keep me in tune with what he was finding and what he wanted to do. On one call he was questioning the factory piston to wall clearance. He had measured the pistons and considered that if they were installed in the standard 4” bore the clearance would be .0025”. He said that was tight for a forged piston. I told him those are the factory forged pistons that were made by TRW specifically for Ford and installed when the car was built from the factory. He asked if I could find the factory specs for him which I did. Factory spec range was .0015”-.0030” with most commonly finished assemblies left the factory between.0020” and .0025”. That was comforting to me because the number he was finding on his own measurements was .0025”. So he was spot on the measuring with regard to how Ford puts these engines together. After I gave him the factory specs he said, “well, I guess that’s how Ford put them together”. Nonetheless he thought it was a bit tight so he elected to make the final clearance at .0030” which is still snug for a typical forged piston in a performance build.
I did some research and learned that not all forged pistons expand the same amount when subjected to high heat from performance applications. The amount of expansion can depend on the exact alloy makeup of the piston. Some expand quite a bit while others only minimally. While you can look up the various alloy mixes of aftermarket pistons, neither Ford nor TRW disclosed the alloy makeup of these factory TRW forged pistons. I suppose I can assume the alloy makeup is of the less expansive type but I have been unable to confirm because the mix was never released.
Do any of you have any knowledge of Fords decision to set these clearances or knowledge of the specific alloy makeup of these factory TRW forged pistons?
  • Informative
