  • SN95 4.6L Mustang Tech
Blower Cams
  • Thread starter Thread starter jasonh_86
  • Start date Start date Oct 3, 2005
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 3, 2005
  • Oct 3, 2005
I've been seeing a lot of people talk about getting blower cams and other people getting N/A cams, what's the difference? Other than the obvious, that they're built for cars with blowers.. Do blower cams put out more power with a blower than a N/A cam would? What are the good and bad of each?
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 3, 2005
  • Oct 3, 2005
anyone?
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Oct 3, 2005
  • Oct 3, 2005
i dont have an answer for you, but i wanted to tell you that you need to clean out your inbox so i can reply to your PM's
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 3, 2005
  • Oct 3, 2005
haha my bad.. here we go.. try it again
ADRENLN
2,342
NJ
Oct 4, 2005
  • Oct 4, 2005
n/a cams will put out more power on a n/a car then blower cams on the n/a car.
right now im n/a. i have blower cams so my dyno #'s could have been 10 rwhp higher with n/a cams.
blower cams will in turn make more power on a blown car then n/a cams.
there are some cams that kinda fit in the middle from what i hear and perform decently on both blown nd n/a cars.
imo i think you are a little better off with what goes with what.
Blown00GTAuto
182
Washington DC
Oct 4, 2005
  • Oct 4, 2005
Well put.
Also, as far as the differences in specs for N/A and blower cams....
Superchargers push an unnaturally high amount of air through the intake which allows much more fuel to be burned, and that produces more power. This increases the need for exhaust flow well beyond what stock cams provide (same thing applies with nitrous). Blower oriented cams tend to offer plenty of duration on the exhaust, with less emphasis on intake duration, because air is being forced in. Additional valve lift is also helpful, also for N/A.
The hot N/A cams tend to have a lot of overlap and this is bad for a S/C because exhaust and intake valves are simultaneously open too long. In this case some of the boost gets pushed out the exhaust. On a N/A setup, intake air is not under pressure, so airflow into the cyclinders will be enhanced by the scavenging affect of overlap, i.e, the exhaust is still open and helping to draw in the air coming through the intake.
My experience is with Comp 270's which I think fall somewhat in the category of middle-of-the-road, since they are very good off-the-shelf 'blower' cams and they do well N/A. The increase in output with a S/C is usually double what you'd see N/A.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
