blown head gasket again? or just loose lower intake?
Gunnerm1
Need you opinions.
I just finished putting AFR heads on my stang. It was running good for about 200 miles then I noticed that it was running on seven cylinders and had more crankcase pressure than normal. No steam , just pressure. I pulled my plugs and found that cylinder#2 has a trickle of coolant being pushed out when the motor is turned over.
My question is , is this most definitely a head gasket, or could the heads and lower intake need to be re-torque.
Other than the water the engine is running fine.
i would redo the gaskets and re torque after 1 hour or so of run time is there any oil in the radiator or water in the oil it will look like a chocolate milk shake after enough water or oil mixes ive been there
Im getting air in radiator, but no oil in water or water in oil. Its kinda strange.
I know i installed all gaskets the correct way. I really feel like i cracked the block, due to the crankcase pressure i was getting. I had to install a valve cover evac system, and route my pcv to the intake side of my blower, to cut down on oil leaks.....guess its time to build a 347, its was a stock block , rebuilt right before I bought it, but i have no idea who did it or if they did it right.
here is a pic of the engine bay after I filled in all of the holes and painted it, to bad I cant get it to run as good as it looks....
no need for sealer on the upper bolts. Pretty sure you don't need to torque the head gaskets to 100ft/lbs, and it is normal to do that many sequences on the intake.
100 ft/lbs on the 7/16" head bolts???? :eek: Why???????????? You need lube on the upper bolts, whether it be sealent or oil. I use sealent to keep the torque specs the same.
