Blown Original T-5??????????????????????
revedup
63
S.F. Cal,
Hello fellow stangers got a blown t-5 in an 89 5.0 ran great clutch good for 217,000 miles but guess it was time .
I put it in1st i reved it , it bangged into neutral.
Now when i put it in gear and let clutch out car does not move .
I can hear faint bearing whine same in any gear!
Stangers wat ya think??
used tranny?
New tranny?
Rebuild this tranny?
Another car?
im guessing a used tranny and lot of labor might work
I dont really think i can find a place to do it.
I wonder how much labor?
Anyone changed a t-5 by themself in their garage?
Whay would a shop charge for labor to install a used tranny?
to rebuild and instal
any ideas would be nice Thanx!!!!!!!!:nice: :rolleyes:
assuming you busted a couple gears, it'll probably be around 400 - 500 to rebuild, depending on how much you've broken. i bought a used one with 2000 miles on it a couple months ago when i blew mine and when i put it in, 2nd was shot. so watch out for deadbeat sellers. i suggest either buying a rebuilt one from a reputable company or person....probably be between 700 - 1000, or have your current one rebuilt. take the transmission out yourself and take it in, it'll save you a lot on labor.
When I did my T5 I just had the car on jack stands in the garage. I was able to get it in and out by myself though a extra set of hands would be really nice. There are any number of things that could be broken to do that. You won't know for sure till it comes out. Personally I don't trust used trannies especially if it's a T5unless its from a car I already know. What is your budget would be a good place to start.
Kevin
Maybe rebuiding original might be way to go??
Put it in 4th and see if it moves. If it does, you blew the input shaft.
That means you'll need a new input shaft and a new countegear and a basic rebuild kit.
That also assumes the bits of teeth didn't fly into your other gears and chew them up.
I'm in the same boat. Went into 3rd and the trans started knocking. I've been on the trans patrol for a week and here's what I run into.
- If you can buy a new one or rebuild all the better.
- You can find a junkyard T5 starting around $100. A fair price for a used, but not abused, less than 80K T5, is between $300 and $500. However you do run the risk of buying a T5 in which you don't know the history off and may end up back on Stangnet biotching about T5 problems.
- If you can buy from someone with a used T5 for sale that is honest and it hasn't been beat on to badly, go for it.
Good luck. :nice:
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
You will also need a magnetic base and dial indicator to measure the endplay ($40-$120). http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=1303&PMCTLG=00
Check out MW classifieds I'm mama'sGT, All I have is my word but
I promise you this T-5 is awesome!!!!!! It was new in May 2006, I bought the car in August 2006, I live in small town so don't drive very far and have only put approx. 3200 miles on tranny if your interested REPLY!
