Blub Blub Blub Blub Hmmm I hear 5 . oh's rumbling around the corner
MustangLX-5.0
856
Lehigh Acres Fla.
Yeah. really....this place IS dead.The "V6 forums are dead" thread is too long to read through.
Thought I might make it look a little more active.I'm thinking more people are either getting 4.6's or the newer S197's .Though I might add I'm not a fan of the latest gen Mustangs.I work at a Ford Dealership in the service dept.I drive the new Fords every day right off the line.The 4.0's are ok but still seem slow.The exhaust on those have an annoying burbling sound much worse than 94 - 04 3.8's.And the 5 spd trannys have too much bearing nouse through the shifter bezel.GT's are much better off.And they sound like they come stock with Borla exhaust.They are much quicker if they come from the factory with the 3.73 gear ratio..and you also get it with a 5 spd.Overall though the way the whole car looks.....I think it's because they made it too long front to back.If they were a little shorter they'd look a little better IMO...
Just a space waster post..
Well sorry I didn't reply much sooner.I hate working so late and not having time to do things because you get so tired out from it.
As of what I remember,the 4.0's were around 210 - 220 HP.The V6 Explorers also are 4.0L's.Though they seem like they get off the line faster than the V6 Mustangs.May be programming or it may just be a different gear set.
If it were up to me and I had to stay with a V6 in a Mustang for economy purposes,I would remove the 3.8 and put in a 4.0.What bugs me the most about newer engines are the fact Ford uses plastic upper intake plenums......Gaaaahhhh...plastic...can't port them and an aluminum aftermarket replacement is hell expensive.Perhaps It's just better to port the stock 3.8 and go from there.
For sound and performance...it's V8's all the way.
