Bmr Springs
70bronc
I'm completely new to 2wds and I bought a 1997 mustang vert gt it's got low miles but say for 9 years with minimal driving so now I'm catching up with maintenance.
I need to replace the a arm bushings, the power steering pump and ball joints so I figured I may as well lower it while it's out.
My questions are 1 what is the quality of these springs I see they are pretty inexpensive. Should I spend more for better springs? This is a daily driver and cruiser for me so I don't need race spec stuff.
And 2 if I lower it do I need anything other than the springs or can I use all other stock parts
I'm more worried about the front right now I have like 4 inches of wheel gap the rear isn't as bad so I was only going to do the front for now since I'm pretty low on cash. When I do the rear is that all stuff the has to be done for it ride right? Like I said it's a daily for me not a race car. If I drop it 1.5 to 2 inches in the front do I need anything other than the springs? Or do I need struts cc plates or anything
@Roanstang - Mustangs prior to 2005 did not come with panhard rods. There is an aftermarket one available which is adjustable. I really wish they came with them. These cars would handle soooo much better.
We can drop these cars (up thru 2004) with only cc plates and proper struts/shocks. You can probably skate by on the stock cc plates and shocks struts if the drop is less than 1.5". However, to do it right and save some tire wear, I would do the cc plates at a minimum.
Reactions: Roanstang
