body work gurus welcome
PeteyAce
346
walking to my car, and ive notice an indent by the rear drivers side close to the door (no scratches or paint from another car). This Pit mark (water mark what ever they are called) its about 2 inches from the line going across the body of the car. As soon as i seen it i cursed my brains out because i know ever nick and dent on my car and that was not there before. i have a few more throughout the car and wanted to know the procedure to get rid of them step by step. I'd figured sand, bondo and repeat until its gone. But not sure on what sand paper to use or what body work tools. And my body filler seems to dry in a matter of seconds no matter how little hardening creme i put in it.:shrug:
Heres a long one......two options.
If your existing paint is nice and you just have a couple dings, I would call a paintless dent guy with a good rep. I had a black 97 Cobra, never painted.....
4 dings in driver door
1 HUGE dent in the passenger door and 3 dings
2 dings in left quarter
2 dings in right quarter
I waited 1 month for this "reputable" dent guy to come out. WORTH THE WAIT. I paid him 200 dollars for about 2-1/2 hours of work. He worked most of that time on the HUGE dent. The others were a matter of minutes. You could not even see where the dings were. When I sold that car...the guy who bought it was like..."There is not a ding in this car!!" I said "I know....:D "
However, I have seen cars where some dent guy worked on it, and a small ding wasn't all they way out, and it had 7-8 prick marks in it. SO....do some research before calling the first guy in the phone book.
If you absolutley must paint it, bondo it...etc.. With small dings, I hit the spot with 80 or 120 grit and use a small filling putty. There is no need to grind it down with 24 or 36 grit and use bondo unless it is a large dent that needs hours of blocking and priming.
To finish sand everything, I hit the car with a DA and 320 or 400 grit. If it is a metallic color or a black car I am refinishing, I always wet sand it with 600 and then 800 grit after I finish sand it. After paint and clear...I hit it with 1500 and 200 grit wet sand paper and rub it out....looks PERFECTLY FLAT!!
well im planning for a paint job come spring, so right now my car is a few diff colors,just prepping the car so then it wont hurt the bank to much . Im guessing use body filler bondo?
All of SVT32V's advice is really good. It sounds like if you're getting ready for paint, then filler is the cheapest solution.
My fiance's mustang was damaged by hail this summer and we had a PDR (paintless dent repair) guy make the repair. Absolutely unbelievable results.
the above advice is good, depending on the dent, try not to go over 1/8" thick on the filler. If you can get it out w/out filling it, do it. You may need a 1/16" or so skim coat of filler, but your not cavin 'n pavin! I try to metal-finish everything as close as possible, just so i have a skim coat left......to much filler bothers me, and if its to thick, it will eventually crack. Also, im not a fan of "bondo" brand filler, if your serious about doing the bodywork, go with a good brand plastic filler such as Evercoat which should be available at any local jobber. Ya usually get what ya pay for, as with the paintless dent removal. good luck
