Bolt chain down to pull motor...
  • Thread starter Thread starter bynummustang
  • Start date Start date Aug 31, 2006
bynummustang
Seen my other Jackstand?
Jul 24, 2005
NC State University
Aug 31, 2006
  • Aug 31, 2006
Long title, and most likely a very short answer.
I have now been told 3 different places that I "MUST" bolt the chain down when I pull the motor out.
Person 1: On the heads, very back on one side, and the other side very front
Person 2: On the intake, opp. sides, and offset
Person 3: Get the adapter piece that bolts to the top of the lower intake.
Thanks pal(s)!
I'm pulling tranny out in one piece if that makes a difference.
R
R2D2
Aug 31, 2006
  • Aug 31, 2006
2-3 bolts in each head
bynummustang
Jul 24, 2005
NC State University
Aug 31, 2006
  • Aug 31, 2006
TTT
4G-KDMP
935
CA
Aug 31, 2006
  • Aug 31, 2006
i agree with person 3:
T
TheUser
1,859
Springfield, MO
Aug 31, 2006
  • Aug 31, 2006
I used a load leveler, which I'd assume is almost required if pulling the tranny w/ the engine. I did it a couple ways: I bolted one side of the chain to each head front and back and I used grade 8 bolts that threaded in most of the way, but I'm not sure if that's necessary. I did pretty much the same thing the other time, but used the same head for the front and the opposite head for the back.
Here are some pics:
Mavrick
2,264
Collingwood, ON
Aug 31, 2006
  • Aug 31, 2006
This is all over rated.. I've had great luck with 1 bolt in each head, one in the front and the other in the back diagonal from eachother.. also using header bolts, stock brackets which bolt to the heads with header bolts..
I wouldn't lift it with the intake unless you have the plate the bolts on with all 6 bolts.
PS I did the motor/tranny at once with the stock brackets using header bolts.
bob331T76
76
so cal
Aug 31, 2006
  • Aug 31, 2006
ALL 3 ways work just fine....no need to trip
ls1beater4eva
334
mooresville
Aug 31, 2006
  • Aug 31, 2006
i have pulled all my smallblocks with 1 bolt in front of the head and one in the rear even when the trans comes out too its all about chain positioning. all these ways listed above work well i personaly just never felt comfortable lifting a motor by the intake.
T
TheUser
1,859
Springfield, MO
Sep 1, 2006
  • Sep 1, 2006
I don't think I could have pulled mine out w/ the tranny and the timing cover, etc on the front w/o using the load leveler. I don't feel like trying to angle a 350-400 lb object on a hoist and shove it in an engine bay. I guess w/ more than one person it would be easier, but I did mine all by myself.
Either way, Good Luck
silvergt2001
48
Houston, Tx
Sep 1, 2006
#10
  • Sep 1, 2006
  • #10
I use two bolts and a serpentine belt? maybe not the safest route but its quick and easy and i've never had a problem doing this.
blkcobra50
209
#11
  • Sep 1, 2006
  • #11
One bolt in each head worked 4 me
JChalfan
551
Bellevue, WA
Sep 1, 2006
#12
  • Sep 1, 2006
  • #12
Are you kidding?
On 5.0's I usually use the stock brackets that attach with the header bolts. You can get away with 1 bolt at the front and 1 at the back too, but try to use grade 8 if you can.
A load leveler is always helpfull too, especially since you're pulling the tranny too. Any of your 3 methods will work, but personally I don't like using the intake bolts.
Jeff
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Sep 1, 2006
#13
  • Sep 1, 2006
  • #13
Wow,you guys make me feel like I have got my engine in with stone age technology....
10,000lbs tow strap,ceiling hoist,1 bolt on each side of head (4 total) with the strap going around them.I put it in with the trans bolted up.I have also done the same thing,only with the strap runing underneth our intake (super victor W351).
Works just fine,as long as you put a little muscle into it.
50FoxBodyGT
74
Memphis
Sep 1, 2006
#14
  • Sep 1, 2006
  • #14
I've always just bolted straight to the lower intake manifold and never had a problem. A load leveler is always nice when pulling the trans out with the engine especially if the radiator is still in the car. Nice pic, blkcobra50. Is that your stroker motor going in?
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Sep 1, 2006
#15
  • Sep 1, 2006
  • #15
The best way would be to use the stock brackets on a stock engine. There the ones that are bolted to the heads were the headers are! Or if ya know anyone with these barrow them, or any of the sugestions above will work EXCEPT the serpintine belt! I wouldnt want to trust that? peace
john
Help! Problem with replacment window regulator motor
  • TTSaleen
  • Oct 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 24, 2025
General karthief
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
C
Knocking after pull- went away?
  • Connormcclark
  • Oct 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 6, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
squeak93
