Bolt in roll cage?
MustangMatt1966
1,004
Orlando Fl.
Hey guys, i have been looking for a roll cage and i have found some that "bolt" in to like the floor or something, they also allow use of the back seat but have an optional bar that goes back across and allows use of a harness...........does anyone have experience with these cages and how easy or hard are they to install? do they come pre welded? ect. thanks guys,
Matt
Matt,
I think I mentioned this on the VMF...
Just be SURE that you can actually retain your rear seat. My old roll bar was advertised as being able to use my rear seat when if fact it would have required cutting it up to fit. Not that I'm bitter about it though....
:bang:
I put in an Autopower race rollbar. Mine has the diagonal bar as well as the harness bar. Mine installed without the need to do anything to the seat, but I did have to drill holes in the metal interior quarter panel covers. Technically you could use the rear seat, but anyone sitting there would likely be kissing the harness bar. You can see some pics of mine and my install info here
http://www.2mfffabshop.com/rllbar.htm
To be honest, it was alot easier to install than I had anticipated. The hardest part was drilling the holes, but the PVC method worked great. There are 3 pieces to the one I bought: Main hoop and 2 legs. I installed the main hoop with only the passenger seat removed. Once in you lean it forward to install the legs. Fairly simple.
