"bolt on" disc brakes question for vacum line location
65fb302v8
20
we purchsed a front power disc brake upgrade kit for mpb and have painfully:bang: gotten all the lines in place mounted the booster, proportioning vlave and bolted up the calipers and discs. now we are stuck on where to tap in for the vacum line. we have a 302 and theres 2 choices, 1 off of the carb or the back of the intake manifold which also is used by the auto tranny. weve been told to use the tranny tap and use the carb and also been told to use the carb and not the tranny tap.
thanks for all suggestions
marc
Originally posted by 66fb302v8:
tim where did u get the T fitting b/c carquest came up with something but i think we could fond somethin better
thnx
I took a 1/4 NPT 90 degree to 3/8 inverted flare adapter for the brake booster, and I drilled and tapped it for 1/8" NPT 90 degree to 1/4 inverted flare adapter to the trans.
It's been working for a few years.
