Bolt size? Cat back to mid pipe
GRGT1994
1,034
Does anyone know the bolt size for the connector between the cat back and the mid pipe? One of mine fell out, and I'd like to run to the parts store and get it.
I just got a 3/8 NC 3" or so long bolt and nut when one of mine got stripped. Just measure the length and use that method. Make sure you will have enough thread to tighten the clamps all the way.
Scott
Thanks Scott. I ended up using a 2 1/2 inch of the same thread depth you mentioned. And while I was at it, I adjusted the catback to push it a little bit more away from the tank and subframe rail. Cleaned up the rattling. Much nicer now.
