  • SN95 4.6L Mustang Tech
Boost-a-pump
  • Thread starter Thread starter Nathen4.6
  • Start date Start date Mar 10, 2007
First Prev 2 of 2
Nathen4.6
34
Central Florida (352)
Mar 11, 2007
#21
  • Mar 11, 2007
  • #21
Yea I'm just getting a new fuel pump.
jivepepper
776
Under a Sombrero. in WV.
Mar 14, 2007
#22
  • Mar 14, 2007
  • #22
stangman said:
mine is here, cause i don't wanna mess with it & in case you don't recognize where that is, it's behind the trunk paneling
Thats how mine is you don't have to use the hobs switch. That way you don't have the spikes and dips.
I'm running my BAP in between the inertia switch and the FPDM (fuel pump driver module). I then have hobbs /boost switch hard wired together so its always on. The I run the rich/lean switch wide open. So its always on and full blast all the time.
If the fuel pressure is to much, the ECU detects it, and cuts the power being sent to the FDPM. Which allows the ECU to control the BAP output by varying the volts sent to BAP and FPDM.
If you hook it up after the FPDM you have to hook up the hobbs switch and it takes longer for Ecu to detect the pressure change and that's the reason for the spikes and dips.
Here's a thread about it.
http://forums.************.com/power-adder/48368-any-pics-bap-install-sct-way.html
Please insert modular depot in one word for the link to work. gezz
04YELLOWGT
1,135
Indiana
Mar 14, 2007
#23
  • Mar 14, 2007
  • #23
Good Choice!
As I stated before, if your looking into making 420+rwhp you might want to look into a Cobra Tank and pumps. My SVT Focus pump was damn nearmaxing at 420 rwhp and now at 440 I am maxing it.
jivepepper
776
Mar 15, 2007
#24
  • Mar 15, 2007
  • #24
04YELLOWGT said:
Good Choice!
Your not driving it that way are you?
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 15, 2007
#25
  • Mar 15, 2007
  • #25
yeah, definately not safe.
i pegged my Focus pump at 423 & tim even set the limiter lower until i could get it taken care of. Then I was going down to MPH to pick up some suspension pieces. Well I got on it getting on the interstate & it flashed a SES light so I took it easy the rest of the way down. Igot there & we tested it & it turned out that it was a low fuel rail pressure light.
tim - you're going to blow it up that way
me - so um yeah, do you all have any BAP's in stock?
tim - yup
*Rhonda rings me up & I install it in the parkign lot*
V_Eight
617
ATL
Mar 15, 2007
#26
  • Mar 15, 2007
  • #26
I'm running a BAP on a 400rwhp GT with a stock pump. It is running lean now, so the pump is failing. My SVT Focus pump is on the way, and that, in conjunction with the BAP will give me the needed fuel all the time.
04YELLOWGT
1,135
Indiana
Mar 15, 2007
#27
  • Mar 15, 2007
  • #27
Yea for now I am. The thing is it only maxes at about 5.6k rpms and I only take the car to 6k. We checked everything over and I didnt lose any fuel pressure so Im "good". Im still pretty easy on it 99% of the time any way though. Plus I should be getting the Cobra Tank and Pumps in the next 2-3 weeks.
One question though.
If I have an SVT Focus pump can I just buy another Focus Pump and then buy the Cobra tank?
y2k02
83
Mar 15, 2007
#28
  • Mar 15, 2007
  • #28
My bap is also wired to run all the time. I have no spikes.
E
El Diablo
53
#29
  • Mar 15, 2007
  • #29
You still need the Cobra sending unit...
I did a write up on it...http://www.badmustangsclub.com/forum/showthread.php?t=13769
DiMora
59
#30
  • Feb 20, 2009
  • #30
I just added a BAP today.
Tim at MPH said I was maxxing out my stock pump.
My "butt dyno" says it feel stronger...I wonder if the ECU was limiting me via the IPTS sender...and now that I have lots-o-fuel pressure it is letting me have all it can make?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 20, 2009
#31
  • Feb 20, 2009
  • #31
Nearly a year old.....way to utilize the search function.
DiMora
59
#32
  • Feb 20, 2009
  • #32
You're darn right!
:search:
First Prev 2 of 2
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • brandyn200
  • Jun 20, 2026
AeroCoupe
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
New fuel pump relay
  • Scrapla347
  • Nov 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Scrapla347
N
New Member from New York
  • NYFox
  • Jan 19, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 25, 2026
AeroCoupe
