9350coupe New Member May 11, 2005 109 0 0 chicago Jul 18, 2005 #1 Jul 18, 2005 #1 where do most of you guys hook up air line for boost gauge? How much vac should gauge be reading on average?
GroverDill GoldMember Founding Member Aug 18, 1999 5,442 1,490 214 Demotte IN 46310 Jul 18, 2005 #2 Jul 18, 2005 #2 There is a spot on the vaccum tree (on the firewall) just remove the plug and connect it there. I see 13 vaccum at idle, my cam sucks (custom is on the way)
W wildstang87 New Member Jun 9, 2005 96 0 0 Jul 18, 2005 #3 Jul 18, 2005 #3 yeah, should be between 10and 15in at idle. then boost at loads
DarkProphet Founding Member Aug 19, 2002 391 0 0 Quakertown, PA Jul 21, 2005 #4 Jul 21, 2005 #4 I connected my boost gauge to the vac line running to my bypass valve. Will this line work? i see 22 in of vacume and only 2 lbs of boost. any ideas?
L luckythirteen13 New Member Jul 19, 2005 648 0 0 Anaheim, CA Jul 21, 2005 #5 Jul 21, 2005 #5 i get 19-20 at idle but im N/A
