  • SN95 4.6L Mustang Tech
boost questions
  • Thread starter Thread starter baggett3_27
  • Start date Start date Jul 25, 2010
baggett3_27
35
RAF Lakenheath, UK
Jul 25, 2010
  • Jul 25, 2010
What size pulley do I need to run on a V1 T-trim with an inlet power pipe, non-intercooled, 75mm TB ,C&L upper intake plenum, long tube headers, and high-flo cats. I want to run about 10 PSI, and hopefully just break the 400rwhp mark. Any input on this matter will help. I'm still running on my 1999 stock block and hope it holds out until next summer. If 10 PSI is to much just let me know what you think is sufficient to make the power I want.
Three50won
1,135
64
69
Jul 25, 2010
  • Jul 25, 2010
I'd say play it safe and start with a 3.60 pulley and a good tune. On a set-up like yours, a T-trim should get you around 8-10 lbs and around the 400 hp mark...I probably wouldn't push a stock bottom end too much further past that.
M
mat82284
889
  • Jul 25, 2010
baggett3_27
35
RAF Lakenheath, UK
Jul 25, 2010
  • Jul 25, 2010
OK guys thanks for the replies, but I'm also torn between fuel pumps. Kenne Bell boost-a-pump, SVT focus pump, or a Vortech 255lph pump? I've read that some guys only get about 380hp out of the focus pump, and that's why I'm a little confused.
Three50won
1,135
64
69
Jul 25, 2010
  • Jul 25, 2010
The only Vortech pump I know about is the T-Rex and that won't work on the returnless fuel systems that come in the 99 up Mustangs. The Boost-A-Pump is not an actual pump, it's a device that allows the pump to push more fuel. Any 255lph intank pump along with a Boost-A-Pump should be all you need. Some people like the Focus pump and there are a lot of other aftermarket 255lph pumps.
baggett3_27
35
RAF Lakenheath, UK
Jul 26, 2010
  • Jul 26, 2010
SuperchargersOnline.com :: Product: 255lph "small" In-Tank Fuel Pump for 1998-2004 Mustang & Cobra
I know you can't run the focus pump with a boost-a-pump because it pulls to many amps. I'm just wondering what some of the guys making 400rwhp are running.
C
cronin49
Banned
Aug 12, 2003
432
SC
Jul 26, 2010
  • Jul 26, 2010
I have the Novi 2000, non intercooled, and put down 417 hp. See my Sig.
baggett3_27
35
RAF Lakenheath, UK
Jul 26, 2010
  • Jul 26, 2010
Here is some cool info someone may find useful
http://www.kennebell.net/techinfo/general-info/BAPsvtFocus_kens.pdf
Forced Induction Vortech v3 low boost (like 2 psi)
  • 92Rustang
  • Jul 29, 2024
3K
Fox 5.0 Mustang Tech Oct 2, 2025
Mindseye007
Boosted fuel pressure regulator questions
  • 92Rustang
  • Jul 13, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2024
92Rustang
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
