Boost ?????
  • Thread starter Thread starter nonosstang
  • Start date Start date Mar 18, 2004
nonosstang
142
Newark, CA
Mar 18, 2004
  • Mar 18, 2004
Would it be possible to run 8 psi of boost on a 10:3 CR motor? Street car.
brianj5600
1,964
Middle TN
Mar 18, 2004
  • Mar 18, 2004
Not with pump gas.
6Stang7
1,470
Livermore, CA
Mar 18, 2004
  • Mar 18, 2004
Even with race gas you'd still be pushing it. Drop it down to 9-9.5:1 at least.
-Shaun
sand1man
299
Charlotte, N C
Mar 18, 2004
  • Mar 18, 2004
with the right tune and right enternals you could but it might get kinda costly
TurboDoctor
1,008
San Marcos, Texas(Austin)
Mar 18, 2004
  • Mar 18, 2004
if you run an intercooler you would proably be ok, just need to keep the egts low as possible. 8psi of peak boost is not to bad, If it was my motor I would either bring down the boost or bring down the compression.
imshaggy2000
960
Orange, CA
Mar 19, 2004
  • Mar 19, 2004
I'd have to say no. 10.3 is a high for a NA street engine let alone a boosted one.
slapper
447
  • Mar 19, 2004
I would have to agree. That's pretty steep compression.
I've swapped heads to larger chambers, and lowered compression in the past with success to allow for small amounts of boost.
T
Fuel P0193 on a 2003 3.8 v6
  • Treemaster5000
  • Aug 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 18, 2026
Treemaster5000
T
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
C
96-984.6 COBRA MOTOR
  • COWBOY2.3
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
COWBOY2.3
C
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
