  • SN95 4.6L Mustang Tech
BOOSTED CAMS???
  • Thread starter Thread starter KidCapri50
  • Start date Start date Apr 1, 2007
KidCapri50
40
  • Apr 1, 2007
Sorry did not have time to search, but I have a procharged GT with stock bottom end and need to know what is recommended for cams , valve springs and retainers as far as boost goes. What company and/or specs. Any info is great.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Apr 1, 2007
  • Apr 1, 2007
look into VT cams they have a good selection for F/I cams the specs vary depending on the stg you get
TweekedGT
1,274
Alberta
Apr 1, 2007
  • Apr 1, 2007
Check out Crower as well. They are really good cams.
jivepepper
776
Under a Sombrero. in WV.
Apr 2, 2007
  • Apr 2, 2007
I picked up 86rwhp from my S292 cams, and Lt's with no other changes. I was having trouble with it breaking up a little bit on top. That's because of a bad ground on my KB BAP that I finally found and fixed. The tuner said if it wasn't for that I would have seen 15 more. I just dropped them in with the AFM cam tool, and I'm still using the stock valve springs.
A
APiratesLife4Me
  • Apr 2, 2007
cam swap
When you say you just dropped them in.....How long a project was it and do you have a sweet lope at idle? I'm looking for a nice bit of lope sound at idle but don't want to sacrifice too much idle quality or vacuum on my 99 auto vert. When I put the x303s in my 89 auto vert, the sound was awesome but I had to give it a second or 2 before I backed out of the driveway because it felt like the power brakes were a bit slow to pressure up I guess maybe the combination of the cams and underdrive pulleys was a bit over the top for the power accessories?
jivepepper
776
Apr 3, 2007
  • Apr 3, 2007
I probably had 6-7 total hours in it. They only have a 531 lift but an advertised duration of 292 but is actually around 242 at .050 lift.
Heres a vid it wasn't quit warmed up, so the idle was little higher than normal.
04YELLOWGT
1,135
Indiana
Apr 3, 2007
  • Apr 3, 2007
Id did the VT stage2 Blower cams and springs they sound great and the car pulls soooo much harder uop top.
C
Chris00GT
275
York Springs, PA
Apr 3, 2007
  • Apr 3, 2007
I also have the HP 292S in my car with stock valve springs. With the cams and a retune with from 460rwhp to 530rwhp. The car pulls the whole way to redline. The only thing is you'll lose some low end grunt with the cams.
spederman
732
  • Apr 3, 2007
would it be too much for the stock block/internals to handle if i got blower cams? (see sig for setup/HP)
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
