Bottoms out...
  • Thread starter Thread starter MahFiVeOh
  • Start date Start date Jun 4, 2004
MahFiVeOh
531
9
49
Ontario, Canada
Jun 4, 2004
  • Jun 4, 2004
I just installed my lowering springs recently and once in a while i can feel it bottom out in the rear if i hit a decent sized bump in the road. Do i need to get a new "bump stop" thingy for the rear? Not sure about the proper name
PS Any way to find out what kind of springs i have? I bought them used and the guy didnt know what kind they were.They were light blue in colour and came with red coloured air bags for rear. They dropped the car about 1.5 inch all around.
Thx
ALMOST STOCK
1,250
41
88
CA.
Jun 4, 2004
  • Jun 4, 2004
You may need a shorter pinnion snubber. It's a good possibility that that might be your problem.
I know there not H&R springs if there light blue.
http://www.maximummotorsports.com/HRsprings.asp
MahFiVeOh
531
9
49
Ontario, Canada
Jun 4, 2004
  • Jun 4, 2004
Where would i get a shorter pinion snubber, any way to modify it and make it shorter?
ALMOST STOCK
1,250
41
88
CA.
Jun 4, 2004
  • Jun 4, 2004
Here ya go.
http://www.maximummotorsports.com/MMPS.asp
patdow1
201
Murrieta CA
Jun 4, 2004
  • Jun 4, 2004
Where exactly does that pinon snubber go? I have H&R's and forgot to install mine, I thought that my Bilsteins shocks/struts would take care of any bottoming out problems.
10HoleLX
257
Southern California
Jun 5, 2004
  • Jun 5, 2004
My BBK springs are Baby Blue but also have BBK painted on them in white
ALMOST STOCK
1,250
41
88
CA.
Jun 5, 2004
  • Jun 5, 2004
It's bolted to the floorpan above the pinion.
http://www.maximummotorsports.com/instructions/MMPS.pdf
This is what the bracket looks like thats bolted to the floor with the OEM Pinion Snubber
stangbear427
2,401
New England
Jun 5, 2004
  • Jun 5, 2004
Are you saying that they didn't? They should have, as they have thier own internal bumpstop. I'm not positive about this, but if I remember correctly I didn't use the pinion snubber and I've been running my Bils for about two years, never once has my suspension bottomed itself out- what spring rates are you using?
patdow1
201
Murrieta CA
Jun 5, 2004
  • Jun 5, 2004
I read the instructions pretty well and you are correct it does say that the Bilsteins have their own internal bumpstops. But It still bottoms out in the front when I go over speed bumps, it doesnt do it in the rear where the pinon snubber is. Do you think my Maximum Motorsports caster camber plates have something to do with my bottoming out? As far as my spring rate I'm using H&R Sports (Specific to the Vert)
Thanks ALMOST STOCK, I kinda had a idea that was where it went after installing my exhaust a couple of weeks ago, Just wasnt sure.
stangbear427
2,401
New England
Jun 6, 2004
#10
  • Jun 6, 2004
  • #10
Hm... wonder if they sent you the wrong springs? Are you sure the rates you have is the rate they said you need? Are they marked? Are you sure it's the suspension bottoming out and not the car bottoming out? No, the C/C's wouldn't have anything to do with it, they'd have to be so far out of proper alignment that you'd know something was wrong by how bad it handled, and your tires would look like somebody was torching them. Did you buy the shock and springs together- and who from?
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
Progress Thread Low Mile 89 GT Restomod - Done with the red, onto the trim
  • KRUISR
  • Jan 4, 2025
  • 3 4 5
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 20, 2026
KRUISR
M
Gifted a Junk 1976 Mustang II with plans for a radical conversion!
  • MXGerry
  • Apr 29, 2025
2K
1974 - 1978 Mustang II Talk & Tech Mar 12, 2026
MXGerry
M
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
