- Mar 5, 2006
- 20
- 0
- 0
I posted this over in the 5.0 section but then l realized it's more appropriate in this section because a lot of you guys are doing the same thing - putting a 5.0 in an older car....
I bought a '91 motor from a coworker. I'm going to put a carb, front sump pan and V-belt system on it. I am looking at buying a 1963-1982 gasket set but I'm wondering if the timing cover gasket will work (I'm using a '91 timing cover and don't want to change covers because this one has already been machined for the gear drive clearance.). Do the different timing covers require different gaskets? Are there any other gaskets I may have trouble with?
Later I plan on switching over to serpentine but it's just too much of a pain right now getting the brackets, pulleys, pump, radiator, etc.
Also, where can I buy an oil slinger? I looked on ebay and didn't see any there.
Thanks,
Oldbutspry
Thanks,
Oldbutspry
Didn't know that about the LTD setup (never saw all of it LOL), thanks for the info.
