This is my first fox body mustang. Its an 87 GT 5.0 5 speed. it has a rebuilt tranny, crane cams, k$n, and flowmasters. There are several problems I have.
1. The engine overheats.
As I was driving it home today it overheated probably 3-4 times. The first time it overheated over the red line until I couldnt even see the needle anymore. Then one of the hoses popped off. so I pulled over, tightened the hose, and filled it up. Then it overheated again and it was leaking out of the radiator cap. I waited till it cooled off and filled it back up with coolant and water. Than it overheated again a little while later. This time it was leaking out of the thermastate housing. i just waited till it cooled off and then filled it up again. The last time it just overheated and the fluid went into the overfill box. Luckly I finally made it home. What could be the problem here? I know there could be several places to look but where should I start?
2. Weird dripping noise in engine
When the car overheated for the last time, while I was waiting for it to cool down I started to hear this dripping noise in the engine. It was pretty fast but it didnt start until about 10 minutes after it overheated and about 5 minutes after I filled it up with water. When i tried to start the car it didnt start immediately and before I started it again I could hear the water dripping really fast somewhere in the engine (not the radiator). What could this be?
3. Engine bogs sometimes.
I have some kind of crane cam on the car so it does have somewhat of a "rough" idle. When Im at a stop light or jsut starting the car it sometimes will stall if I dont keep my foot on the gas. It was running fine when I test drove it at the guys house. This bogging was happening when the engine was really hot and overheating. Could that have something to do with it?
4. Ticking
I am pretty sure this is just a loose rocker but it kept getting worse and worse as the engine got hotter and hotter. Is that normal?
There is some smoke coming out of the exhasut sometimes but very little. It is sometimes white smoke and other times black smoke. Again it is very little and i does this when it is very hot...about to overheat.
Thanks
4. Ticking
Thanks
