Bouncing speedo fix
  • Thread starter Thread starter BullittAndy
  • Start date Start date Nov 12, 2006
BullittAndy
139
  • Nov 12, 2006
This post is mostly for future searchers but any comments added are appreciated. I just completed #3 and it cured the last of my bouncing speedo blues.
Bouncing speedo fixes. I've used all three and each provided improvement.
1. Replace speedo driven gear.
2. Replace cable. (Mine was resting on exhaust)
3. Disassemble speedo gauge cluster and lube the speedo mechanism. Also the speedo uses magnets to operate and if they are not aligned then the speedo will bounce. I could hear scraping after I disassembled the gauge cluster and so kept tweaking and oiling it until it was silent.
It now operates perfectly above 20 and bounces slightly below 20.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 12, 2006
  • Nov 12, 2006
Interesting comment about the magnets. Have you checked RPM to road speed to make sure the speedo calibration is good?
MikeC
240
SLC, UT
Nov 12, 2006
  • Nov 12, 2006
What did you use for lube?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 13, 2006
  • Nov 13, 2006
The proper cable lube is a small tube of graphite compound. It is available at most auto parts stores. You are only supposed to lube the lower half of the cable. This prevents the lube from working its way into the head and gumming up the magnets & rotating disc.
MikeC
240
SLC, UT
Nov 13, 2006
  • Nov 13, 2006
That's for the cable, but BullittAndy said he lubed the speedo mechanism.
  • dan50
  • Jul 18, 2026
dan50
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
79-86 Mustang Instrument Voltage Regulator (IVR)
  • sparkylawdog
  • Sep 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2024
Rcdgl
R
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
M
  • mnky99
  • Sep 5, 2025
mnky99
M
