When i had my engine bay stripped out for painting I decided to replace my rusting brake booster with a replacement piece from pep boys. Think I paid about $80 for it with core. Anyway, its a rebuilt model.
So as I am bleeding the brakes getting it ready to test drive, I'm discovering my pedal feel wasn't the best, soft mushy, going to the floor. Then I noticed when I depressed the brake pedal, I was hearing a air hiss. This hiss was coming from the vac hose attached to the brake pedal that has the valve that opens when you depress the pedal. So for giggles, I pulled the hose and valve off the pedal to mess with it. With the valve off, the hose is sucking air all the time, causing the hiss sound, and of course the valve opens it when its pushed in. Plugging the hose up while i push the pedal feels better, although its desperately trying to still suck air. My question is, is this normal operation? I don't recall if this was like this before I took the car apart so long ago. I also tested the cruise control switch on the brake pedal, didn't change anything, I removed the cruise control stuff from the car completely so the switch is probably useless now.
Is is possible to hook up the vac canister wrong and have a problem like this or is my brake booster faulty? I'm NOT looking forward to pulling out that booster again!
