Just put in the Granada swap with 74 Maverick MC non power or booster. Here is my question. My brakes are very spongy. In order to get some pressure you have to pump the brake pedal several times. At that point the pedal will become a bit more stiff. However, if I don't pump the brakes for a minute, that pressure that just built up will fade and the pedal will hit the floor. Also, now when I bleed the brakes there is no air in the tubing coming from the speed bleeder. I used a suction unit to the bleeder and was pulling the fluid out with the pump from the driver front wheel and when it comes out under pressure somewhere bubbles are getting into the line. I am thinking there is a small leak but I can't figure it out. What do you guys think?
