1993 GT, stock 4 lug brakes. I am leaking brake fluid from the area where the master cylinder and brake booster meet up. I believe this is because of a bad gasket, which only cost about $6 at the parts store. Is this generally what causes this?
Also, I really hate to replace the master cylinder because I want to do a 5 lug disc conversion sometime in the next year. If this repair does require a new master cylinder or brake booster, is it possible to use a SN95 setup with the stock 4 lug disk/drum setup?
Thanks in advance!
Joe
Thanks in advance!
Joe
