Brake Fluid Opinions?
krang00 said:
I'm going to powder coat my calipers and while I'm doing that I'm also swapping out the stock brake lines for stainless steel braided hoses. My question is what type of brake fluid do you guys recommend?
From http://www.tceperformanceproducts.com/faqs.html -
TCE suggests a quality DOT 3 or 4 fluids for most applications. Do not use high temp racing fluids unless you plan to flush the system daily and keep this fluid in your car fresh all the time. High temp fluids can be great for a short while, but over time they degrade faster than more conventional fluids. They are also more susceptible to moisture and need continued flushing and bleeding to maintain their operational level. Simply adding ‘racing brake fluid’ won’t do a thing to make your brakes work better unless you have a fluid boiling problem already.
Thanks for the info, I wasn't planning on putting "race brake fluid" in. I'll probably just go to Autozone and see what they have :)
Anyone know of other places to get stainless steel brake lines from though?
