brake fluid sensor question on conversion
  • Thread starter Thread starter 1993whtstang
  • Start date Start date Aug 25, 2011
1993whtstang
146
Massachusetts
Aug 25, 2011
  • Aug 25, 2011
hi
I was looking at doing the SSBC brake conversion kit from late model restoration, the one that is $699 with everyhting needed, pads, slotted/drilled rotors, 73mm calipers,stainless hoses, master cylinder,etc.
It comes with a new master cylinder that does not have the fluid sensor harness on the resorvoir like the stock master cylinder. The guy a SSBC said that the brake light would always remain on the dash. He mentioned there may be a way to bypass it
Has anyone used this kit, and if so what did you do with the brake harness so that the brake light will not show up on the dash. Also, were you happy with the kit?
Thank You
ID89GT
1,659
18
49
Spokane Valley, WA
Aug 25, 2011
  • Aug 25, 2011
The light wont be on, it will be the opposite, and never turn on from that sensor. The sensor acts as a switch when the float gets to low and makes contact, thus turning on the brake light. You could find out what the master cylinder is for and maybe run the the junkyard and just cut the plug off and rewire it onto your car.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Aug 26, 2011
  • Aug 26, 2011
I think it's a 1" bore MC which I never felt was the roght MC for the application. There is no sensor for it as the sensor was in the combo valve those years.
I think leaving the switch unplugged wil leave the light off, but if you don't use a jumper wire, you might not have an e brake light.
I dislike that kit simply for that reason.
1993whtstang
146
Massachusetts
Aug 26, 2011
  • Aug 26, 2011
Thank you for the information!
Any suggestion on a front brake kit? or should I just update to slotted rotors and stay with stock calipers and update stock brake booster and master cylinder?
Thank you!
ID89GT
1,659
18
49
Spokane Valley, WA
Aug 26, 2011
  • Aug 26, 2011
4 lug or 5?
1993whtstang
146
Massachusetts
Aug 26, 2011
  • Aug 26, 2011
ID89GT said:
4 lug or 5?
4 Lug, thank you for any info on a good kit
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
  • dan50
  • Jul 18, 2026
dan50
