hi
I was looking at doing the SSBC brake conversion kit from late model restoration, the one that is $699 with everyhting needed, pads, slotted/drilled rotors, 73mm calipers,stainless hoses, master cylinder,etc.
It comes with a new master cylinder that does not have the fluid sensor harness on the resorvoir like the stock master cylinder. The guy a SSBC said that the brake light would always remain on the dash. He mentioned there may be a way to bypass it
Has anyone used this kit, and if so what did you do with the brake harness so that the brake light will not show up on the dash. Also, were you happy with the kit?
Thank You
Thank You
