Brake help
  • Thread starter Thread starter Neltech
  • Start date Start date Jul 9, 2011
Neltech
40
  • Jul 9, 2011
found my linelock failed so i bypassed it
now i can't get the brakes to bleed right. i can't get any pressure.
fluid will come out of the front bleeders but not the rear.
pump for days and no pressure. there is a tiny bit of resistance about halfway through the brake pedal stroke but other than that it just goes to the floor
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jul 10, 2011
  • Jul 10, 2011
Did air get into the MC? If so you.ll need to bench bleed.
Is there an adjustable prop valve? You need to turn it to full out to bleed the rears.
Could also be a pinched line, blockage or something else. Is this oem brakes or some sort of 5-lug brake setup?
Neltech
40
  • Jul 10, 2011
all OEM
pretty sure I need to bench bleed it from what ive read on other forums. thanks man!
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
G
2019 GT Line lock
  • gray owl
  • Jul 18, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jul 25, 2026
gray owl
G
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
