Brake Issue after Installing SN95 conversion
  • Thread starter Thread starter Blown331LX
  • Start date Start date Oct 11, 2007
Blown331LX
227
Chapel Hill, NC
Oct 11, 2007
  • Oct 11, 2007
I have a 1990 GT that I've been building for the past 2 years and finally got it driving a few days ago. First I'll give specs on car then describe the problem and ask for help and advice. Car currently has SN95 spindles and balljoints, dual piston PBR calipers, cross drilled rotors and the steel braided lines from Maximum Motorsports for the conversion from stock hard lines to the PBR calipers. The rear is the stock brake drum setup with the exception of the Moser 5 lug axles. No the problem is that the brakes dont feel great and dont stop on a dime like I thought they would. It almost feels like the pedal isn't as firm as it should be or as if the rears are doing most of the work. I have not swapped the master cylinder or proportioning valve cause I didnt think it was needed. All the lines have been bled multiple times and are free of air and the rear brakes are in good adjustment. Im really lost as to what to even look for. It doesnt feel like a bad master cylinder but it just doesnt feel like performance brakes but more like the factory brakes on my 1977 F150 lifted 4x4, to give a comparison. All input is welcome..........
GSP393
217
Orange County, Texas
Oct 11, 2007
  • Oct 11, 2007
Contact Richard at North Race Cars. He is a genious when it comes to brakes, esp. fox 5 lug swaps.
http://www.northracecars.com/index.html
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 11, 2007
  • Oct 11, 2007
I'm not a genious when it comes to this stuff, but my guess is that you need to swap the master cylinder and the brake booster. The stock booster was designed for such small brakes and now that you have the 2 piston calipers it might not be able to give you the necessary help. I imagine the master cylinder needs to be swapped out as well. I'm not sure about the proportioning valve but I imagine that since the fronts are dual piston calipers and the rears are drums you probably need to adjust it as well.
ttop88
42
indiana
Oct 11, 2007
  • Oct 11, 2007
I vote master as well. Since you still have rear drums you don't need a differant prop valve. I used the master off a 88 lincoln lsc.
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 11, 2026
keel
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
