BRAKE LIGHT SWITCH
tom23
55
CT
Ok I just finished swaping out my pedal assembly for the t-5 swap. OK now my brake lights don't work. I was wandering if this is the way you put the brake booster rod back on. First I put on the push rod bushing, then the brake booster rod then I think you put the brake switch on with the U-Shaped side first. Then the push rod spacer washer. Followed by the cooter pin. Is this right or do I have something backwards?
Where is the white tip?
