  • SN95 4.6L Mustang Tech
Electrical Brake Light Switch
  • Thread starter Thread starter Shane8996GTLX
  • Start date Start date Oct 22, 2017
  • Tags Tags
    brakes electrical
  • 3
  • 4
  • 5
  • 6
First Prev 5 of 6 Next Last
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 23, 2017
#81
  • Nov 23, 2017
  • #81
I took the test light and followed the red/gr wire from front to back where it splits off to the third brake light. I'm assuming that means it's a ground issue since I have confirmed power of the wire ?
Reactions: General karthief
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 23, 2017
#82
  • Nov 23, 2017
  • #82
Now do the opposite, hook the test lead to known power and trace your grounds.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 23, 2017
#83
  • Nov 23, 2017
  • #83
Where are all the ground on a 96 mustang bc I haven't found a good diagram
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 23, 2017
#84
  • Nov 23, 2017
  • #84
Each light socket has 2 wires, one is power, the other is ground.
I'm figuring you found power all the way to the light sockets correct
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 23, 2017
#85
  • Nov 23, 2017
  • #85
Yes I did the test light to both sides
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 23, 2017
#86
  • Nov 23, 2017
  • #86
The brake lights are grounded at G300 for the 1996 Model year. Per the Ford service manual:
G300 Below rear of center console
There are also several splices between the trunk and center console area.
But the ground can be confirmed in several different ways. One method is the extend the lead of the test light to where it will reach the battery positive. This will allow the test light to light when the probe is grounded. Confirm that the light works by touching to bear metal in the trunk. Better yet located the green grounding terminal fuel pump ground on the left side of the trunk.
Once it is known that the test light works, then touch to the ground connection of the brake light. IF the ground is good the test light should light. IF not, then the ground isn't working.
For further proof of the diagnosis put the test light on the power side of the rear brake lights. The test light should light each time the brake pedal is pressed.
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 23, 2017
#87
  • Nov 23, 2017
  • #87
Do it how wmburns discribed and be spacific with the results, I couldn't describe it better.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#88
  • Nov 24, 2017
  • #88
Ok so I didn't have much time today to figure things out. I saw a black ground wire that runs to the emergency brake below center console. I put new brake bulbs In. I have a feeling fuse 1 15 amps is faulty. And needs taken out for further assessment. Test light won't read/light up but will on one side with fuse removed.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 24, 2017
#89
  • Nov 24, 2017
  • #89
There may be a problem with I/P #1, but it's NOT what is causing the 3rd high mount brake light to not work. The high mounted 3rd brake light goes through I/P #9.
Also note that I/P #1 is only supposed to have power in "run". Did you have the key in run when the test was done?
Besides the very first test was to verify power at the brake on/off switch. Soooooo it's seems very odd to me why dropping back to a possible fuse problem.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#90
  • Nov 24, 2017
  • #90
No power with the key on run For fuse 1.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#91
  • Nov 24, 2017
  • #91
If there is physically bolted ground wires in the trunk I haven't seen them but like you stated under the center console rearwards I only saw e brake ground
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 24, 2017
#92
  • Nov 24, 2017
  • #92
Now I'm confused.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#93
  • Nov 24, 2017
  • #93
Sorry ! I'll just keep trying to figure it out
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 24, 2017
#94
  • Nov 24, 2017
  • #94
Did you veryify grounds at the brake light sockets?
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#95
  • Nov 24, 2017
  • #95
Yes but I can do it again in case I missed something. I know G300 or whatever is a ground but like I've stated a few times, I don't see any other ground besides the one on the parking brake.
General karthief
Mod Dude
Aug 25, 2016
28,140
10,761
213
polk county florida
Nov 24, 2017
#96
  • Nov 24, 2017
  • #96
I meant at the sockets, I don't think there is a wire back there in the tail light area that grounds to the body, I want you to verify power and ground at the sockets for the third brake light, two wires, one ground, one power,
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#97
  • Nov 24, 2017
  • #97
I'll look into this tonight or tomorrow.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 24, 2017
#98
  • Nov 24, 2017
  • #98
Is the key in run power in/out fuse I/P #1, #10, and #7? IF no power in all (3) fuses THEN there's a failed ignition switch.
IF there's power in the other I/P fuses but not in in I/P #1 then there's either there's a fault INSIDE the I/P fuse box or an error in the test.
OBTW, there's TONS of other systems also grounded at G300. Seem like IF the ground itself were bad then other things would be affected. So it seems more likely to me that a spice point or there's a break in the wire itself between G300 and the trunk.
Shane8996GTLX
Active User
Oct 22, 2017
61
Illinois
Nov 24, 2017
#99
  • Nov 24, 2017
  • #99
Just fuse 1. Funny the test light doesn't pick it up but the volts meter will.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 24, 2017
#100
  • Nov 24, 2017
  • #100
^^^^This is a dead giveaway that the connection is not capable of carrying current. The test light places an actual load on the circuit. Sooooooo IF the VOM says there's voltage but the test light does not, be on the look out for a high resistance connection.
Corrosion, Water, Rodents!!
  • 3
  • 4
  • 5
  • 6
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Fox 5.0 Mustang Tech Tuesday at 11:58 AM
Dakar09
D
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
