Brake line problems???
  • Thread starter Thread starter Blue67fastback
  • Start date Start date Sep 24, 2007
Blue67fastback
21
Cape Cod
Sep 24, 2007
  • Sep 24, 2007
Hi folks,
I have a problem with low PSI (300) at the rear brakes. 700 PSI on the front! The car has a Stainless Steel power conversion kit from drum to disc on both front and rear. The intermediate brake line going to the rear distribution block is 3/16 ID. Is that to small, should it be 3/8 ID? Because of my cam, vacuum pressure at idle is 10 lbs, I know that way to low and I have a canister installed already, But I see an elec. vacuum pump is in my future. thanks, Bill
SoCalCruising
2,437
SoCal
Sep 24, 2007
  • Sep 24, 2007
Does this the PSI at the rear respond to changes made to the proportioning valve?
Blue67fastback
21
Cape Cod
Sep 24, 2007
  • Sep 24, 2007
brake line problems
No, I have one on the rear line but it only changes the pressure about 100 psi. I emailed Stainless Brakes but no word yet. Having spent almost $2000 with them I hope they can help with some tech support. Both rear brakes over heat after driving only about 5 miles and we were very careful to make a proper install. I'm not really impressed with their system.
Blue67fastback
21
Cape Cod
Sep 24, 2007
  • Sep 24, 2007
Brake line problems
Also, the pads that came with the brake kit for the rear, were junk. They chattered & squeaked big time. Finally found an aftermarket set of disc pads for (89 Thunderbird turbo) that stopped it.
NasaGT
1,993
Virginia
Sep 25, 2007
  • Sep 25, 2007
Rear brakes overheating with low pressure? I'm not a drum brake expert, but my guess would be that a drum residual valve is still in the rear system.
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Sep 25, 2007
  • Sep 25, 2007
are the rear brakes able to stop the car at all?? the braking should be 60% front and 40% rear or so... sounds like you are on par..... i think....
69gmachine
576
Southern Maryland
Sep 25, 2007
  • Sep 25, 2007
3/16ths line is normal for all the lines. When you measured the brake force were you standing on them as hard as you could or just applying the brakes casually? Both numbers sound way too low to me.
Otherwise, did the kit come with it's own distribution block or are you using the original one that came with your drum brakes? How are you determining an overheat condition?
Sponsored New J&M Release: 2024+ S650 Full Front + Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Mar 6, 2026
MRaburn
Sponsored New Release: 2024+ S650 Brembo Rear Stainless Steel Braided Brake Lines
  • MRaburn
  • Mar 6, 2026
MRaburn
How to Route Subframe-Style Intermediate Brake Line?
  • cnorman31
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 29, 2025
cnorman31
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Sponsored New J&M Release: 2024+ S650 MagneRide Front Brake Lines
  • MRaburn
  • Mar 6, 2026
MRaburn
