I have 2000 mustang spindles on my 92 but the block thats sits on the spindle at the end of the brake line doesnt sit right on caliper. I do have the half of the line that screws into the 2000s calipers, can these be mated with the lines in my 92?
What the hell block sits on the spindle? Do you mean the square end of the stock softline? You need the '99+ softlines, and on the passenger side you'll need an adapter for the softline to hardline (Weatherhead 7828).
I had to grind the little block off my caliper, even using Russell steel braided lines. Without doing that, the line rubbed my tire. If you grind the block off, you can use your fox lines IF you use the banjo bolt from the sn95 lines.
