I've been having some vibration with the front brakes for a couple of months. Car has 42K miles on it. Finally decided to get them fixed, so I took it to a shop that is supposed to be good. Anyway, they said that the rotors needed turned (which is what I expected) and they recommended getting new pads. They said that if you put the old pads on with turned rotors, they wouldn't work very good and would probably squeal. This sounded a little weird to me, but I figured the pads probably only had another 15K miles left in them, so I agreed to new motorcraft pads. It this true about turned rotors and new pads?
Also, they asked me if I had work done on the brakes before b/c one of the pads was missing a shim and the pads are ceramic. Then they told me that the pads they put on were not ceramic (they are ford motorcraft and cost $89 for the set). So I asked "Are you telling me you put a lower quality pad on the car?" They said the pads they put on the car are cheaper, but probably won't warp the rotors b/c they don't get as hot as ceramic. Is this true? Do ceramics perform better but put more wear on the rotors?
Third question...should I be doing anything special to break these new pads in? They used to say that you should not ride the brakes when the pads are new because they won't break in properly...though I wouldn't do that anyway. My last couple of cars were leased, so it's been about 10 years since I had new brake pads put on a car.
They don't seem to stop as well as the old one, but I'm guessing they gotta break in, right? (I guess that makes 4 questions.)
Thanks
Thanks
