Debating whether or not to use 66mm or 73mm calipers. I planned on getting 94/95 spindles and in theory want the best brakes. Better meaning larger, asides from dual pistons (which I can't afford at the moment). So this would lead me to conclude using crwn vic 73mm steel piston calipers, ie SVO used 73mm. But would I run into fitment issues? Would it be best to go with the extended 8mm +96 spindles? Or would the stock sn95 66mm calipers work just as good, if not better. Fyi I don't do track or race, an occasional red light or abandoned road maybe. I also plan on keeping my rear drums for awhile and using slotted front rotors. Any help on this would be appreciated.
