Brake Problem Please Help
jchav02
116
29
49
I was installing cobra rear brakes on my mustang today and ran into to a problem. The block on the flex line that connects to the caliper seems like it is too big. I'm stumped I cant figure out whats wrong I've got the LH caliper and bracket on the drivers side. Anyone have any suggestions?
Hmm, Ive just barely put the bolt in so it grabs and the block can move up,down, left, right. I cant get it to clear that lip no matter which way I move it.
I'm saying that I think the hard line is supposed to go down under the e brake spring. Your's goes up. I just finished mine yesterday too. The only way that line would bolt up is how I described it to you. Now I have a set of rear coil overs back there, and there wasn't any place where I could even mount that goofy bkt, so I cut mine off. I agree, it seems wrong and it fit better bkt wise for the hard line to go up, but like I said, the bolt would only go in one way.
There are others like NikwoaC that have done this swap, maybe he can enlighten both of us.
You either have the wrong parts, you're putting them on the wrong side, or you're assembling them wrong. Sorry I can't help much more than that, my stuff just went right together without any trouble. Make sure you are using the correct soft lines.
I think Im just going to take everything off recheck everything hopefully I can find the problem. Im thinking that its something with the softlines.
Well if you have the wrong soft lines,... We both have wrong soft lines. Look at pic in my progress thread, I have a pic of the soft line attached as the only way it could go. If that is " wrong," then I can't imagine what is right.
Well I just finished going over it again the only way I was able to get the soft line to connect was flipping the the brackets upside down as you did madmike1157. Where did you get your soft lines from?
OK, I just looked at my car, and I believe how you have the soft line mounted and how you are attempting to attach it to the caliper in the pictures IS correct. The side of the banjo bolt "box" where the counter bore breaks through the side wall should face down and away from the tab on the caliper. Also, my brake lines are routed up like yours are, and the soft line bracket is mounted in basically the same fashion.
So, this leads me to believe you're using the wrong parts. Are those 94-95 soft lines? What brake calipers are those? Are those the correct banjo bolts for the calipers?
That's all I got. I don't know why else they wouldn't just bolt together.
Mine came in a kit from N.R.C. If they are supposed to orient up, then I can't use them anyway. ( again the coil spring will be in the way)
I got the N.R.C. cobra kit so all the parts should be 94-95 mustang. Here is a pic I got from ebay of M.P.S. rear ends they sell which is the same parts then mine .
See below, found problem!
OK I checked my current stock of lines and they are appear to be the same as pictured.
If you get lines and they are right excellent if not there are a couple of options, grind the block tab off of the caliper or grind the block, neither of which I like. We have ground the caliper in the past when using some aftermarket lines. If you do grind the caliper make sure to plug the hole.
Look at the pix and triple check you have them AND THE CALIPERS on the correct side. Richard.
SEE BELOW
Found the problem, the calipers are mis cast on the boss. Took a set of calipers to the OE Ford casting of a bad caliper and compared to the new caliper (Ford no longer sells them so we have had them cast).
The ford is .53 the fitting is .49 and the NEW casting is .48
I have called the supplier to find out what happened and to fix the problem.
In short the best answer is to remove enough of the boss to get the line to fit.
I appologize for any issues but new lines are not going to fix it, it is a caliper issue that we will get resolved ASAP. Richard.
